So I gave my VW to 'professionals' to fit a kitchen and my RIB using the correct Kiravans fitting kit.
The kitchen they fitted didn't work with a rib and they ended up fitting the rib in the wrong place.
Because of this have drilled holes in the wrong place in chassis frame and actual fitting kit. As per picture.
A correct kitchen has now been fitted. The chassis wholes will obviously need rust proofing filled and painted or welded.
I also think it's worth getting a new fitting kit?
only issue is I think the seat is slightly in the wrong position to fit through the standard pre drilled holes..... maybe 10mm to far to the left as you look from the rear of the van?
would appreciate anyone thoughts?
