Bulb warning light on dash even with bulb monitoring switched off.
bdnck
So I've recently upgraded the lights in my T6 to THQ V3 headlights with LEDs for H1 main and H7 dipped.
I've switched off bulb monitoring using vcgs (with the help of a fellow forum member) for both low and high beam (bit4 & bit7) but the warning light is still showing even with blub motioning switched off.
Has anybody else had this issue and found a work around?
Or does anyone know what else I can try to remove it?
Spoke to thq and they could only really advise to do what I've already done with the vcgs but will let me return the bulbs if I can't fix the warning light.
I've attached what faults it's showing on my carista
Really don't want to have to take them out and find alternative bulbs.
Any chance it was done wrong way?
No it was definitely done the correct way, we figured out it was the opposite of what was listed in the vcgs from the instruction video
Reactions: mmi
