Hi guys, hoping someone could maybe shed some light on the issue I am experiencing. I have a VW T6.1 2021 plate. The issue I am experiencing is the air coming out the heaters in the cabin. No matter what setting or direction either hot or cold or with aircon or not - the heaters are blowing full hot. As you can imagine, after some time this becomes uncomfortable and means we have zero aircon come summer. Today was only 13 degrees but inside the van felt like it was a scorching summers day. No change of setting will change the heat coming out the ducts. Even with the air flow on lowest setting there is still heat being generated into the cabin.
