Hi, I need to run cables rom underneath drivers seat to behind side panel behind drivers seat. 1x16mm, 4x25mm, 2x phono and 4 speaker cables. Can anyone advise the best route please ?
Thanks Nat
Thanks NatView attachment 257287
At the top left corner of where you removed that panel is a route through to inside the B pillar, from there you can feed down and then out where the seat belt is. then follow the OEM wires under the seat.
