Max Palmer
I would like to retrofit rear speakers to a T6 conversion done by Cascade (big mistake not to have gone for the speakers originally as the kids can't hear their music in the back without turning up the volume a lot). As it's post conversion, cable routing will be a bit more difficult. I think I'm content once the cable is at the roof section (either passenger or driver side above the chairs) to route the cables for speakers along the edge of the cut out roof and not go 'inside' the van as you won't really notice them. However, what is the best route to get the rear speaker cables from the media unit to this location. Reading other threads, people seem to go across to the passenger pillar and then up this (via the glovebox) and then where? Can some give a more detailed description of how you would feed cables through this route and what you would need to remove (trim wise) to do this?
Also, has anyone got any recommendations for very low profile rear speakers,
that might be even thinner than these Pioneers that people recommend? I'm thinking about mounting these in one of the roof boards:
Pioneer TS G1732i
These have a depth of 24mm when mounted, which would protrude slightly.
Pioneer TS G1732i 2-Way Coaxial Car Door Speakers [6.5"Inch 17cm 240WEach Pair] | Sustuu
Alternatively, I might go for the 'pods' at skipton audio. Although I'm not totally convinced about the appearance.
rear speaker pods
Are there any general guides to cable routing in vans and how to remove various bits of trim to do this?
Cascade is a lovely conversion BTW.
Thanks,
Max
Pioneer TS G1732i
rear speaker pods
Thanks,
Max
