Cables under passenger Caravelle t6
Dibsta
Hi all Cables under passenger Caravelle t6 can I use any for my leisure setup.
Any advice much appreciated Dave
Take a pic of the fuses mounted at the front of the seat base, this will tell us what you have fitted.
For example, this is mine (also a Caravelle).
80a fuse and 100 relay is the split charge relay for the factory LB
40a fuse x2 is for the electric sliding doors
15a x3 are the 3x 12v sockets - drivers seat base, middle pocket, and rear.
25a is the factory eberspacher parking heater.
Two things I'd have a dig into.
The cable ringed in purple looks quite heavy duty, where is that running to and from? Sometimes cabling might tucked into the loom tape.
The loom to the right ringed in green looks after market (pvc rather than cloth tape) what's that doing and is that the heavy cable?
