CADAC 2 Cook 2 vs 2 Cook 3
aworthy
Anyone got either of the above mentioned CADAC stoves?
Looking at getting a stove and I like the look of CADAC.
I’ve seen the 2 Cook 2 PRO DELUXE QR and 2 Cook 3 PRO DELUXE QR but I can’t workout what the difference is? From what I can see the 2 Cook 3 is 2cm bigger and 1kg heavier?
They detail the differences on the website.
I've got the 2cook pro deluxe QR.
The possibility of discovery is endless with the 2 Cook 3 Pro Deluxe QR. With new features such as; gas ignition protection, bottom heat shield, dual windshields, coffee pot stand and a grill plate handle, the 2 Cook 3 Pro Deluxe barbecue is the ultimate camping companion, whether camping, caravanning or picnicking.
The 2 Cook 3 Pro Deluxe barbecue has an integrated quick release (QR) coupling, so connecting to the gas supply is quick and easy. Plus with dual burners, each with push button piezo ignition, you can cook multiple dishes at the same time, maximising convenience. The addition of a removable coffee pot stand means you can enjoy your morning cuppa without worrying about boiling a large pan, as the 14cm pot stand is suitable for any small camping kettle, percolator, or pan.
Rubber feet on the base of the stove provide extra stability and prevent the BBQ from slipping when placed on a camping table, and two removable windshields are included for use on breezy days. During use, switching between cooking surfaces couldn’t be easier thanks to the included grill plate handle, and when not in use the complete unit packs away in to a convenient storage bag, with separate pockets for the grill plates, grill handle and windshields.
INCLUDED WITH THE 2 COOK 3 PRO DELUXE QR
The 2 Cook 3 Pro Deluxe QR comes with a flat grill plate, ribbed grill plate, 2 pot stands, grill plate handle and a coffee pot stand.
Note: For 2024 models it is not compatible with the 90° Rotating Quick Release due to the integrated quick release.
Our 2 Cook range barbecues will run off either Butane or Propane gas, which regulates between 28-30mBar (Butane) and 37mBar (Propane).
We don’t supply a regulator and hose with any of our barbecues. As they can be run from multiple gas sources there isn’t one single regulator which can be used for all the different gas sources. Therefore our regulator and hoses are sold separately, so that our customers can make sure they have one that is appropriate to their gas source.
Jesus Christ I’ve read that site a few times and it didn’t sink in at all. Blame it on lack of sleep!!
Edit:
I think it’ll have to be the 2 cook 3!
I've got the 2 cook 3 pro deluxe qr (what sort of naming scheme is that!) and it's excellent, apart from being a little too fierce at minimum heat. I use a heat diffuser plate.
