So booked my van in for a Cam belt in a weeks time as it has now covered 83k, what else would you recommend doing now it’s out of warranty and the VW muppets won’t be working on it.
Not fitting a new gearboxDSG fluid & filter
Every 40k iircFluid and filter of DSG box does need changing though. Cant remember the intervals thought off the top of my head.
Every 40k iirc
See attached
That is almost certainly a result of when the technicians were doing the cylinder head work unless a loose stone has been thrown behind the cover (I've read of similar issues for vehicles without a plastic under engine tray) I'm 99% sure Gates are VAG factory fit and when I come to change mine it will be replaced by a Gates belt.View attachment 56826 Well this should be a warning to anyone thinking of leaving there Cam belt as to the state of mine, hopefully you can see from picture , like this in several places, apparently there is an issue with the Gates Cam belt that VW used. Not sure if this was changed to Gates when they did the cylinder head at 30k or it’s the original
Interestingly, cars fitted with the same TDi CR engine are recommended at five years if going by time rather than mileage.
