Can I put LED bulbs in my reversing light without bulb out error- best black smoked LED rears (with Pics please)
Mr Hero
Hi all.
Thinking of upgrading my rear halogen lights to LED's but only worried about the reversing light. Can I just swap over the bulb to LED- sounds too simple!
If not, will upgrade but would like some black smoked (already have red smoked so fancy a change). I know the THQ smoked work well but not too keen on the look- doesn't look as 'smokey' as some I have seen.
Can anyone recommend any other black smoked rears (that don't throw up bulb error)...pics would be good as well
Thanks in advance
Rob
Hi Ukfozzybear
Thanks for the swift response- I've got standard lights at the moment so not sure if this or any LED reversing bulb will work with bulb error
let me know if it will
Thanks Rob
Hi @Mr Hero you can switch the halogen reverse light bulb to LED without error codes appearing. If you mean to upgrade to full LED rear lights this is also easy enough. You will need to replace the connectors as the LED's are different, if you need a link to the correct plug let me know or search the forum as the info is on here. They will work as yours do now however if you run 2 new wires and connect accordingly you will have full use of reverse and rear fogs on both sides without any errors. Again, all the wiring instructions can be found on the forum. As for after market lights, I imagine they will be plug and play and good for use with LED bulbs but can't confirm as never dealt with any.
Hi @Gazbadge thanks for this. I don't hate the look of my lights...wish I could see something when I reverse.
I have seen a couple of threads on suitable bulbs- will just check tomorrow- hopefully save me about £250!
cheers
Rob
Yes you can fit led reverse bulbs with no issues
I fitted these thanks to a forum recommendation (sorry, can’t remember who it was)
It’s like having headlights on the back of your van.
Reactions: Loz
Many thanks Dellmassive and Ali-G
Twenty20 are a good recommended bulb so I have brought some and will await some alumination from the rear!
off to get depressed at watching the football COYS
Rob
Hi Ali G
My twenty20 bulbs have arrived but I'm not sure they look like they will fit...I have original halogen rear lights not LED.
Will have another look but appreciate if someone could just confirm that this bulb goes in without nay adaptors etc.
cheers
Rob
Hi Ali G
I needed the 382 fitment for this bulb so have ordered this- I'm glad that I wasn't so useless that I couldn't even change a bulb!
cheers
