Can you buy this component separately?
mfourc
I’m after the part at No.51 for a T5.1 I’m restoring. Any one of you can buy it separately from the door card? If so what’s the part number? Mines missing this bit.
Try LLL parts or the oem shop.
LLL parts will give you the current part number, diagrams and with an option to order or you can use the part number and Google it on the oem shop.
Failing that, go to vw with part number. You might be surprised, they may cheaper than both.
Thanks. Not heard of LLL shop but assume I can google it. Thanks
Yes mate, on Google.
Their warehouse is in Holland.
You will wait around 2 weeks though for parts, but can assure you they are a legit oem parts wholesalers. No scamming from them
It does have a part number, which side and what colour do you need as there's a bunch of variants. 48 quid each for black.
I’m after both sides as part of a resto project. The cards I have sadly have these bits missing. Will ultimately get them sprayed piano black to match my other parts so base colour is not so important.
Part seems to be the same whether van/Kombi/Caravelle. Part nums and costs for standard anthracite below:
7H6867409C 71N £48.30 Left
7H6867410C 71N £49.74 Right
Talk to your VW dealer if you don't have a TPS account. I imagine they'll need to come from Germany, plus chance they're on back order.
Just looked for you via LLL parts and the oem shop. Not available.
Will have to say that if these guys don't stock them vw won't have them.
Be better off scrolling through ebay and transporter groups.
Try Germanys ebay as well. Normally find these niche little parts from their.
Hi thanks. Assume
back order = need to be Made.
Not necessarily. Until you ask a dealer if they can get them you won't know. As the person above says LLL not having them available is an indicator but I've had stuff from TPS they show as unavailable. If you want the parts you're gonna have to ask the questions at the very least.
I just looked at your original post.
You say part number 51.
LLL parts show this has part number 11.
If this is correct, it is available to order.
Unfortunately only have the right side.
Does this help you
