On diesel engines - no, it does not. Only when engine is running (the pump starts when ignition is turned into START, thus immediately before engine is cranked).Does the in tank fuel pump prime when the van unlocked or door opened?
Yup, same here with my T6.1.I thought on the T6.1 it primes on driver door open? There is certainly several buzzes and whines kicking off in mine when the door opens.
I'll try at some point, but it does involve having the "are you messing about with the van again" conversation with MrsR for assistance with the door.
As an aside if someone wanted to intercept some of the circuits that go through the harness couplers are those connectors easy to get hold of, tried looking but can't find a good search term.
Or is it just easier to depin and intercept that way?
Couple of experiments I'm considering but want to be able to easily return to stock so want to avoid cutting cable or scotch like taps.
Isn't the connector (T6f/T6ao) actually under the van in T6.1 - different than it was with T6??blue/yellow pin
Ah no, not for this, for other projects. Just thought I'd asked as the two electrics wizards were on the thread
Yes the side harness block is the same in the 6.1 but the front relay/fuse frame is sort of reversed with the big fuse strip on the front of the seat and relays a bit behind
Isn't it actually TAK=Coupling point for fuel tank? I think the TSKVL refers only to 3-pin connector next to label "TSKVL" A bit confusing sometimes - agreed...Hmm the wiring diagram says it should be 6-pin black connector in left seat box (TSKVL) but not seen in that image?
The functionality depends also on engine type. The old C-series engines have a simple fuel pump relay as T6 did.
D-series engines have a dedicated fuel pump control unit (J538) running the fuel system pressurisation pump - VCDS data suggests it's PWM driven.
I'm a DNAA engine - I don't see a wiring diagram for that specifically (there is a choice of two)
That's a shame because now it's got my interest I want to know for certain
Time | 06:14:33 | 06:16:22 | 06:18:21 | 06:19:57 | ||
IDE00021 | Engine RPM | /min | 0 | 892 | 893 | 1698 |
IDE07824 | Tank-internal presupply pump 1 bank 1: activation | % | 10 | 25.63 | 26.47 | 28.31 |
IDE07825 | Tank-internal presupply pump 1 bank 1: nominal value | l/h | 0 | 61.7 | 65.1 | 70.6 |
Would the ECU run without ignition on???
If I knew I could disable the auto close on the electric tailgate I'd be right there as having it accidentally close on the deployed rear kitchen is my constant worry - and why I'm thinking of intercepting the wiring with a switch unde the seats either at the fuse or the harness connector - crude but effective.
