Hi all
I have caravelle rails installed into my t6 as I have the sliding triple seat. I want to get my chippie to make me a box for the back that fits into the rails. Does anyone know if the factory spring loaded parcel shelf cleats would fit straight into the rails in the rear without having to remove the black end caps? I know you can remove them at the front end but at the rear end they look bolted in? The idea would be to have a couple of slots in the bottom of the ply box that the cleats could slot into and then screw down directly into the rails without the removal of the black bits - which is what you seem to have to do with the aftermarket ones. When I google pictures all I get is the top part of the cleat with the spring and not the bit that goes into the rail?
TIA
TIA
