I have a brand new damaged caravelle grille, this was damaged before fitting so is in as new condition with the damage you see below
The plastic has cracked a few inches along the top edge, if someone wants take the trims off and glue/plastic weld the cracked bits back together then potentially a cheap posh grille for someone ?
Just to note the stuff you see on the chrome trim is glue residue from the packaging bag and will clean off
In the lower pictures i am pulling the damaged area apart to highlight whats going on and where its split
These cost over £200 new so think £50 is about right ?
I will NOT post this item, it can be collected from Plymouth or i will be at busfest this weekend
