Caravelle owners - help needed please.
Skyliner33
VCDS User
T6 Legend
Hi, if you own a factory Caravelle (not conversion) I would appreciate a bit of help.
I am trying to locate the part number for the outer single rails. The ones with the tie down points at the end. AS in the photo below:
If you van has these would it be possible to for me to use your reg number to get the part numbers to order them?
(The brushed aluminium covers should be about 1930mm long, not including the end caps)
Thank you in advance.
