Carista Beta
The answer to the question is on the Carista website.
Morning all - can anyone tell me if the beta version of Carista is still available?
Typed in the web address as per the earlier answer but comes up with Not Found (iPhone 14)
Found it - downloaded the app onto the phone, no email or redemption code....
Ideas?
Ideas?
My link in post #3 still works. Full instructions are there. You have to download Test Flight first then the beta Carista from there.
Downloaded TestFlight onto my phone but have no email or redemption code - followed the instructions but now hung-up....
Can someone recommend a diagnostics tool which is not mega expensive. Im thinking of purchasing the Carista but need to know it works
I have a 2015 T6 which has run out of fuel and despite 1/2 tank refuses to start
I have downloaded a manual and it is telling me to connect diagnostics to activate the fuel pump.
Can someone help?
The Carista is a good basic bit of kit just to plug in and check for faults and get info about the van.
It gives fault codes (which you need to look up) and, if you pay for a month or a year, can play around with a few settings.
It isn't as good as VCDS or OBD11 but it is more straightforward to use.
However, it may or may not work for 2015 model - you would have to contact them to find out.
Carista works with T5.1, 6 and 6.1. I’ve had a 5.1, got a 6.1 and used on a friends 6 as well.
Sounds to me like you'd need vcds for that rather than carista. If you can hear the fuel pump running when you turn key, chances are the bcm/ecu is blocking it from starting
Sounds odd, I've never heard of this fault before
@jonboymobile I have an older Carista (probably about 4 years old) which is the basic version. This gives the option to prime the fuel pump via the service menu. I’ve just ordered an EVO version, the reason being this can be left in the OBD socket as it has a sleep mode to prevent battery drain (apparently - guess time will tell on that!) I ordered through the Carista app which was priced at £64 using code MWCOLEMAN25 which gave me 25% off (no idea who or what MWCOLEMAN is) getting it for £48. You do need to subscribe to the app but can pay month by month as you need it. It will still carry out some basic tasks without paying anything. My van is 2016 T6 140. The screenshots are using the older Carista.
just signed up and been accepted to beta tester, so should be able to set the dip beam to stay on with high beam, and not sure of what extras it might do yet 🤔:p
Careful - easy to break your current settings. For instance, I managed to screw up my folding mirrors and someone on this forum kindly helped me get them back by going through some very counter-intuitive menu settings.
Make a note of everything you change and only change 1 or 2 things at a time. Boring but less stressful.
