Carista fault code 03444
andrew butler
Found a fault using carista contact-switch ignition 03444 anyone Manchester area can scan it in to have a more detailed scan...? The actual fault is the radio not turning off ir on with ignition and the Bluetooth says it needs ignition on to turn on...??? Cheers Andy
Seems like the second feed is not present?
what year, model infotainment system is it?
