For Sale CBE / 4 ROD CBE Level Probe / Tank Depth 310 / 505140 / New / £10
bobbybasic
£10 collection from Brighton (currently £21.35 from 12 Volt Planet)
Fresh water tank probe for use with the CBE PC100 & 110 control panels.
Note: these are not intended to extend to the bottom of the tank so the metal probes will actually be shorter than the tank depth options shown above.
The 4-pin connector block connects to a matching socket on the wiring harness provided with the PC100 and 110 control panel kits.
Supplied with gasket and mounting nut for fitting to a 60mm diameter hole in your water tank.
If required, these probes can be cut down to suit different tank depths as follows:
  • Shortest probe - Do NOT cut (this detects a full tank)
  • Mid length probe - should be cut to approximatley 1/3 of your tank depth
  • Two longest probes - both should be cut to approximately 2/3 of your tank depth
  • Tank cut-out required: 60mm dia. hole
  • Connector: 4-pin multiplug to connect to PC100/110 kit wiring harness
