This is ‘as new’. I’m only looking for £50.00 plus p&p.
CBE BMTG LPG And Soporific Gas Detector
The "BMTG" gas detector, specifically designed for the RV sector (caravan, campervan or motorhome etc), is able to detect the presence in the air of LPG gas (butane, propane and their mixtures) and soporific gas (ether gas with narcotic effect).There are two calibration levels which can be selected using a configuration bridge on the back of the detector and which allow the sensitivity of the sensor to be adjusted according to use and chosen installation position.
A visual and acoustic signal warns of the presence of gas in the air before it's concentration reaches a tenth of the minimum value needed to trigger and explosion (LPG) or before it has an effect on people (soporific gas). This panel fits also the "BECKER INTEGRO" range.
Features:
- Size: 119 x 60mm
- Detects LPG gas and sleeping gas
- 12v power supply
I’m in South Tyneside if collection is an option.
