CBE PC-100 Control panel upgrade
emjga
Folks
I currently have a CBE PC-100 Control panel , which is very basic for showing the battery usage
Basically you have 4 very small dot that represent the usage
I know CBE do a more modern controller
i.e CBE PC-200
Does anybody know if you can just swap them over
i.e Plug compatible
I think CBE PC-100 has 16 pole connector block
Or is there a better way to get a digital readout on the leisure batteries
Matt
Folks
i.e CBE PC-200
i.e Plug compatible
Matt
I have the same display and have used a BM2 attached to the leisure battery to get an accurate voltage reading. Another option could be one of the plug in voltage meters if you have a cigarette style socket on your leisure circuit.
BM2 - Amazon
Plug in meter example - Amazon
Not sure if I have a ADD Blocker running or the Links are not working.
I assume for a BM2 something like
BM2
I did find a USB meter like this one , that at least seems to work
USB
BM2
USB
Sorry, not sure what happened with the links!
Yep, exactly those you linked. The BM2 is good as it gives you history but you do have to use your phone to see the voltage rather than just glance at a display.
