Ceiling light changeout
JABB
How easy is it to replace the rectangular lights with round led ones? Can I use the power in the roof on the old ones? Ideally I would like the lights to act as the existing ones, on with the doors and also switched on. Will the canbus bar me from doing this?
Yes, just make sure you know which wire is which, there should be a feed from the courtesy circuit(doors open) a permanent feed and an earth. I've fitted a few extra lights using the existing wiring and they work fine.
