I’ve read all previous posts (I think) regarding central locking issues, but couldn’t find my issue.
Need someone to brainstorm with.
I have a T6 Multivan from 2016 (highline, 2.0 bitdi). Last week central locking when using the switch on the driver door stopped working. It locks all doors, but immediately unlocks them. For no apparent reason the already unlockes doors will try to unlock themselves while driving (like if you’d press the unlock button).
Central lock works perfect when using key fob.
I have a diagnostic tool from iCarsoft (CR MAX model) that sprung three error codes:
03302, 03303 and 03304 which mean ”implausible signal” from passenger, rear left and rear right door.
What I don’t understand is how can the key fob work but the driver door switch doesn’t?
The car is not indicating any open doors.
The error occurred after a power wash, so water might have entered, but I try not to spray down into the door panels.
Plan is to:
1. remove fuse
2. disconnect battery (anything special I need to consider here or is it just disconnect and connect once again)
3. remove one lock, make sure it’s dry, WD40 and general inspection (if that clears error for that door, then rinse and repeat for the rest)
Or do the T6 wizards in this forum have more clever ways to suggest?
If anyone has links to good youtube clips regarding this I’d appreciate it.
Cheers,
Johan
Plan is to:
1. remove fuse
Cheers,
Johan
