I have a shuttle ac controller or as vcds says the semi climate control. This one (part numbers taken from ebay ads)
7E0907047F
When on vcds I noticed that the model is determined via can.
I am changing the back to a camper and so the rear heating will be removed, I have also fitted front heated seats but yet to get them wired up and I was hoping to retrofit into the same model but with the heated seat switches.
As a side note to my possibly daft question below, is it possible to keep the controller and use the "rear" button on it for controlling something or turning something on in the back?
7E0907047K
However now with the thought of removing the rear heating all together can I change/upgrade the controller to the fancy digital ones I see? I think I am answering my own question about upgrade here but is the dual zone somethng that can be retrofitted without changing the AC side or can the controller be fitted and dual zone ignored. If it is a case of sensors then I can install them without too much hassle I guess?
7E0907047F
7E0907047K
