Child Lock Ejected From Sliding Door
Farnorthsurfer
VCDS User
Anyone else had the child lock plastic fitting in the sliding door fall at their feet when the doors is opened?
Done it couple of times now. Seems like the plastic fitting is very loose in the hole provided in the door.
Just shoddy tolerances by the look of it.
Anyone else had the same problem?
Still under warranty so might see what they have to say before I glue it in myself.
I had the same issue with the tailgate one (identical part) replaced with a new one a couple years ago and it’s been fine since
Had the same issue with the tailgate version. A dab of superglue, and its never been a problem since.
An old thread resurrected but does anyone have the part number for the sliding door child lock as mine has gone missing?
Just for information should anyone else have to get replacement parts. I needed both the rod and trim. Part numbers are in the photo below.IMG_2671.jpeg
