Hello All,
Hopefully someone can help with what I think is a strange one. Bear in mind mines a 2015 T5 not T6 sorry
Whilst recently instaling 2 new leisure batteries and re-wiring the entire setup I noticed I had no power to the cup holder cig lighter socket and read on here that the fuse was one of the ones under the passenger seat which I then located and replaced with the same 15 amp fuse.
This as happily recharged a torch and mobile phone for me but seen little other use as of yet.
Recently went off for 4 days to give the vans new batteries and B2B charger a good test and bought a little cheap submersible pump for filling the water tank under the sink. This pump is a beauty, seems to be stainless steel construction and shifts 12 litres per minutes but uses a maximum running current of 0.8A according to the instructions.
However if I try to use the cup holder cig socket to run this pump it does nothing at all, after which I have confirmed the fuse is still OK by plugging in a USB adaptor in, however when I plug the pump into the socket under the flap on top of the dash it sucks like a Dyson!
Any ides anyone?
Any ides anyone?
