Bearonfilm
4 x 16” Original Clayton alloys off T6.1 71plate
2 x 4mm tread
2 x 6mm tread
In good condition, £220 - collection from Romford.
Dodo Deadn hex - 33sheets
£35 - collection from Romford - box is pretty heavy, could post but would add the postage to the price.
www.dodomat.com
Kiravans thermo-acoustic 7-8mm foam - foil backed self-adhesive camper van insulation
5.8m on roll £50 - collection from Romford
www.kiravans.co.uk
2 x 4mm tread
2 x 6mm tread
Dodo Mat DEADN Hex 50 Sheets
Dodo Mat DEADN Hex is a self adhesive, foil backed sound deadening vibration damper. Simply cut, peel & stick Dodo Mat DEADN Hex on the interior sheet metal of any vehicle to recuce unwanted vibrations & structural noise. Make those panels as dead as a Dodo! Dodo Mat DEADN Hex has a high...
Kiravans Thermo-acoustic 7-8mm Foam - Foil Backed Self-adhesive Campervan Insulation
This insulation foam is the second step in Kiravans 4-step lining system for ultimate warmth and comfort in your campervan. 1. Sound Blocker 2. Thermo-Acoustic Foam 3. Thermal Fill Insulation 4. Stretch Lining Carpet We've used similar products in our own vans for several years and always...
