Hi all,
I have a 2016 T6 (T30 Highline) with the manual climate controls. First long work drive in months yesterday and noticed the vent control had stopped working. Kind of. Selecting windscreen, feet or dash vents didn’t do anything, although selecting defrost would switch on the ac but not direct any air at the windscreen vents. There was a trickle of warm air coming from the all outlets whatever the setting. Selecting recirculate would create a lot of blower noise, like it was blowing against closed valves. The really weird thing was that using the screen washers had the same effect as pressing the recirculate button - it initiated a loud blowing for maybe 30s, then go back to how it was. Also selecting reverse would do the same, although this later stopped. I’ve noticed since I got the van four years ago that selecting reverse changed the blower noise but because everything worked so I just thought it was odd. I’ve never noticed using the screen washer effecting blower noise before, which seems bizarre.
I had the ac on to keep de-misted in the rain. Outside temp was about 7C. I looked at my ac pipes when I got to work (3 hour drive) and one was thick with ice. That may or may not be related to the problem. I have a hunch it is. I checked for fault codes but there were none.
For the return journey (4 hours later) I kept the ac off and all was ok, vent controls were working as normal. Selecting reverse still changed something and induces blower noise but then it always has. Thoughts?
