Clunky Gear Change
bencoleman1988
Hi All
I'm getting a clunk going into first gear, and most of the time gear changing is a bit jumpy when going up through the gears. All the gears select seemingly perfectly, clutch point is perfect and no slipping. No DMF rattle or strange noises.
One this I've noticed just recently - if I'm changing gear going round a righthand bend (slowly of course) the notchyness almost completely disappears. Could this be an engine/gearbox mount issue?!
Hope someone might be able to shed some light, or had a similar situation!
Thanks in advance all!
To me sounds like the clutch, but might not be anything wrong with it it takes up the slack up in the gear putting it in 1st gear. The Syncro's in these gearboxes don't seem very good, the gears don't just drop in smoothly . most modern cars will change gear without the clutch just by backing off the throttle i wouldn't like to try in in my van.
