No preheat used in video.You surely have verified that the Webasto actually preheats the engine? From factory Transporters are set to heat cabin only and the modification "Engine first then cabin" is done in-country. Unfortunately quite a few have slipped through without the modification
Yes, understood. My question was about "normal" day - you are sure also engine is heated before starting up, not just cabin?No preheat used in video.
Well maintained car, you have to be prepared here in Finland for the winter...Am surprised you even got in the door at that temperature, I struggled at -5° lol
Normally when I use Webasto, then the engine is also warm, it then sound different. I use normally it for 30-40min.Yes, understood. My question was about "normal" day - you are sure also engine is heated before starting up, not just cabin?
@mmi , is that something that can be set using VCDS?You surely have verified that the Webasto actually preheats the engine? From factory Transporters are set to heat cabin only and the modification "Engine first then cabin" is done in-country. Unfortunately quite a few have slipped through without the modification
We had -23° in Friday, the -16 felt warm.-16degC !!!!!
Jeez, were lucky to see -5 in London.
Why the key cycles before crank?
Yes, however a dedicated software for the Webasto is needed to run it as parking heater in addition to "normal" auxiliary heater (which runs only when engine is running). Comes standard up here - quite a few Forum members have retrofitted... see linked threads further down.@mmi , is that something that can be set using VCDS?
Plain auxiliary heater starts when ambient temperature is below +5C AND engine is running - so no heating without engine running. Parking heater functionality can be started independently - from a remote or a timer panel.Also, I thought that the pre-heater works itself when the temp drops. How do you "use" preheat from the webasto?
