Connect rear speaker loom (T6.1) - specialist in/near Gloucestershire?
WHSE
I have a new loom sat in my headlining that needs running to my headunit and plugging in. Probably a very quick job for an expert but I've given up trying to get my instrument cluster surround off. May require the glovebox dropping down but maybe not if the connectors can be squeezed through under the dash.
Can anyone recommend any trustworthy companies that can do this for me in my local area? Keen to find someone that won't leave my dash parts scratched otherwise I may as well do it myself!
Thanks all
Thanks all
It’s really not that bad to do ? I only had my van for about 2 months and took the plunge
Loads of clear videos on line and also as long as the connection are made off then easy to plug in
You got any pictures of your wiring and dash
Which sound system do you have
Thanks all
Woops other thing to remember is that your sound system may not allow the balance of the speakers without a software change ?
Believe me, I had some great input from people on this forum and a good video, but try as I might I could not get the instrument surround trim off. I had it partially off but the bottom section would not move and I was pulling really hard. I drew the line when I managed to slice the tip of my finger on the exposed edge of part of the trim.
Bring back the good old days of sliding your radio keys into the side and the headunit popped out without any trim removal!
