constant squeak
AMD61
i have recently had timing belt and water pump changed also the aux belt and tensioner replaced and now have a constant squeak the alternator clutch has also been done both myself and the mechanic are at a loss any ideas?
For the sake of £12 I'd spray some of this on the Aux belt and see if the noise goes away. At least if it does you know it's not the cam belt causing the issue.
silenced after just a whiff of spray mechanic has checked for wear or deflection next we are going to put a none ac belt on and see how it goes, will update
