Hi,
I've got a T6 LWB Kombi with a Motexion bulkhead and rubber floor still fitted. I need to build a platform in the load space but as I'm not changing the rubber floor and want to retain space below the platform I'm not planning on using uprights to support the platform. My plan is to span across the van from the horizontal beams behind the panels about halfway up the sides (where the trim clips insert)) with say 50mm x 50mm wood and then top with plywood board. Total load including the platform likely to be 100 - 120kg.
Does anyone have experience of supporting weight from these horizontal beams in the rear panels? Will they take the weight?
