Coolant sensor faulty?
Dm85
Hi everyone,
I Noticed that the cylinder head coolant sensor has strange readings compared to the rest.
Monitoring it today the coolant sensors are reading normal and the cylinder sensor is actually decreasing and hovering around 28 degrees when engine is up to temperature.
I’m assuming this would be a sensor fault, or possibly air in system which I doubt. Is there anything else that could cause that before I get a new sensor installed? FYI no fault codes at all?
Pic attached
