Sold Cooler Master 27” GA271 2K QHD 2560x1440 100Hz 1ms Widescreen Monitors
t6blo
Ex-owner
T6 Legend
I have 3x of these bad boys up for grabs because I never learn and repeated a mistake I made about a month ago! (just ask @JOG :confused:)
2K QHD 2560x1440
100Hz 1ms
Widescreen
Tilt Stand
Will run off 12v too so could be used in the van with an Amazon Fire Stick for example.
Can be used with PC or Mac
https://www.coolermaster.com/catalog/setup/monitors/ga271/
Paid £149 each earlier this week, they have had around 7hrs use, absolutely like new, in original box with power supply.
Only £120 inc insured UK courier each.
These are very good monitors - my boys love them for gaming. Very, very sharp picture.
Silly question but what else do you need to run them on 12V? A different power adapter? Looked in the manual but didn’t spot it… cheers
The output of the included mains adapter is 12V / 4A.
So you would just need to buy a barrel plug the same size/diameter as the one on the mains adapter and then wire it into your 12v system in the van.
Something like this...
Or one of these...
Please note these are just examples - you would need to ensure the barrel plug dimensions were the same as the one on the mains adapter.
You would also need an external speaker, or Bluetooth speaker or headphones.
