Cornering fog lights swapped?
Matty2104
Hi T6ers, how are you doing? After over a year with my T6 I have noticed that my corner fog lights illuminates on the opposite side than expected. Meaning that if turn left, an outside (right) fog light turns up.
I asked my mechanic to have a look at it, but he says they can't be put in reverse, so the fault must be electronic in ECU. At first I thought it has something to do with a van thing, so that you don't scratch your outer corner, but several people confirmed they should work the same as usual, illuminating the inner corner.
Has anyone stumbled onto similar issue?
Fog and reversing function is uninfluenced and is working as supposed to.
Any ideas please?
Thanks,
  • Wow
Reactions: mmi
Are the fog lights factory installed or retrofitted?
Are doors open/closed displayed correctly on MFD - right is on right, etc.?
Do you have any diagnostics tool?
With e.g. VCDS or OBDeleven you could turn on each of the lamps individually - just to verify they are wired correctly from the BCM (central electrics).
Fogs are factory-installed. Doors are displaying fine. Even LED lamps are where they should be.
I have a VCDS and Carista. Where should I look for the individual turn on? Are they in Output tests? Is this Central electric or a different module? Thanks
Have they ever worked ?
If not then the two wires could be swapped in the BCM to reverse left and right
If yes then i would :
disconnect battery and 'reboot' the van, see if that sorts it
use a diagnostic tester (VCDS) to check and reset any fault codes and see if that sorts it
use VCDS to activate the left and right fog outputs (module 09) and see if the correct side illuminates
Excellent. Could you please post full VCDS Auto-Scan - I'm a bit curious to compare the codings.
You could test each of the cornering lights individually. The testing is done via Output tests.
VCDS > Select > 09-Central Electrics > Output tests
  • Abbiegelicht links (Cornering light - left)
  • Abbiegelicht rechts (Cornering light - right)
I actually have my worries that the cables were swapped at some occasion. That's the thing, I can't recall seeing them working as designed, but I didn't pay much attention to them before. Compared to my Passat B7, I don't see a big effect on the corner lights. Halogen or LED bulbs (H11), I see them very lightly. The main LED beam is doing most of the work anyway. I am more curious what could have gone wrong.
The car was rebooted a few weeks ago, when I had my car repaired after a crash. I told the mechanic to pay attention to the fog lights and he claims they are connected as supposed to.
I will try the Output tests, but most probably will do that over the weekend.
Thanks for the suggestions
Realistically the cornering light idea is bollox, doesn‘t help in the slightest. If you’ve ‘upgraded‘ to LEDs from one of the popular retailers you’ll find that they are even less effective than OEM.
You can’t see it when driving (hopefully) so don’t worry about it.
All right, so the Output tests confirmed what we all suspected. The fog lights are reversed.
The most important question is...can they be swapped via coding or is this a mechanical switch?
Do I assume correctly, that the harness for the fogs is in the right wheel arch? I have a LHD, I am in Czech Republic. Do you know what cables are connected to their respective lamps? Can a slightly advanced amateur do it himself?
See the VCDS scan below.
Code:
Friday,24,March,2023,22:10:00:00007
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 18.9.0.2
Data version: 20180927 DS296.0
www.Ross-Tech.com
VIN: xXxX   License Plate: xXxX
Mileage: 315570km-196086mi   Repair Order:
Chassis Type: 7H-VN75 (7E0)
Scan: 01 02 03 04 08 09 10 13 15 17 18 19 25 55 5F 61
VIN: xXxX   Mileage: 315570km-196086miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
18-Aux. Heat -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
55-Headlight Range -- Status: Malfunction 0010
5F-Information Electr. -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
Address 01: Engine (2D2D2-CXFA)       Labels:. 04L-907-309-V2.clb
   Part No SW: 04L 906 056 KH    HW: 04L 907 445
   Component: R4 2.0l TDI   H02 6184
   Revision: 23002001
   Coding: 0025401C436401080000
   Shop #: WSC 02737 790 50316
   ASAM Dataset: EV_ECM20TDI03004L906056KH 004013
   ROD: EV_ECM20TDI03004L906056KF.rod
   VCID: 7DF14FF5ECF169A2BE-8028
2 Faults Found:
31103 - SCR NOx Catalyst Bank 1
          P20EE 00 [100] - Efficiency too Low
          Intermittent - Not Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 315307 km
                    Date: 2074.01.17
                    Time: 08:44:48
                    Engine speed: 1331.75 /min
                    Normed load value: 45.1 %
                    Vehicle speed: 50 km/h
                    Coolant temperature: 91 °C
                    Intake air temperature: 11 °C
                    Ambient air pressure: 980 mbar
                    Voltage terminal 30: 14.742 V
                    Unlearning counter according OBD: 40
                    Air mass at air mass meter 1: 86.4 kg/h
                    Extern.temp.sens.1 bank 1: raw value: 10.0 °C
                    Mass airflow sensor 1 bank 1 airflow: raw value: 537.7 mg/stroke
                    Throttl.valve adapt. 1 bank 1: posit feedback - Act.value: 71.48 %
                    NOx sensor before SCR cat conv: offset correction factor: 0 ppm
                    NOx sensor after SCR cat conv: offset correction factor: 372 ppm
                    Reducing agent quality sensor: urea concentration: 209.92 %
                    Reducing agent quality sensor: raw temperature value: 0.0 °C
25126 - Implausible Data Received from ESP Control Module
          U0416 00 [040] - -
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 32
                    Mileage: 315217 km
                    Date: 2074.01.15
                    Time: 13:12:49
                    Engine speed: 1362.00 /min
                    Normed load value: 56.5 %
                    Vehicle speed: 27 km/h
                    Coolant temperature: 87 °C
                    Intake air temperature: 31 °C
                    Unlearning counter according OBD: 37
                    Acceleration: 0.393 m/s˛
                    Cruise Control System (CCS): status: passive
                    Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
                    Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
                    Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
                    Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
                    Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
                    Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
                    Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
                    Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
                    Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
                    Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
                    Drivetrain coordinator: brake function status-ABS intervention: No
                    Drivetrain coordinator: brake function status-ESP intervention: No
                    Drivetrain coordinator: brake function status-EDL intervention: No
                    Drivetrain coordinator: brake function status-ASR intervention: No
                    Drivetrain coordinator: brake function status-MSR intervention: No
                    Drivetrain coordinator: brake function status-Driver braking: No
                    Drivetrain coordinator: brake function status-HDC active: No
                    Drivetrain coordinator: brake function status-ESP invokes TSK braking: No
                    Drivetrain coordinator: brake function status-EPB active: No
                    Drivetrain coordinator: brake function status-ASP intervention: No
                    Drivetrain coordinator: brake function status-ADS intervention: No
                    Drivetrain coordinator: brake function status-Stopping distance reduction2 warning jolt: No
                    Drivetrain coordinator: brake function status-ESP sampled passive (ESP off): No
                    Drivetrain coordinator: brake function status-ASR sampled passive (ASR off): No
                    Drivetrain coordinator: brake function status-ESP recognizes vehicle at rest: No
                    Drivetrain coordinator: brake function status-ACC stopping distance control active: No
                    Drivetrain coordinator: brake fault status-Deceleration sensor not available: No
                    Drivetrain coordinator: brake fault status-Deceleration sensor malfunction: No
                    Drivetrain coordinator: brake fault status-ESP system error: No
                    Drivetrain coordinator: brake fault status-ESP system malfunction due to inaccurate engine torque: No
                    Drivetrain coordinator: brake fault status-ESP indicates TSK message consistency error: No
                    Drivetrain coordinator: brake fault status-TSK/ESP handshake error: No
                    Drivetrain coordinator: brake fault status-ESP automatic engagement malfunction: No
                    Drivetrain coordinator: brake fault status-Brake light implausible: No
Readiness: N/A
Address 02: Auto Trans (J743)       Labels:. 0BH-927-711.clb
   Part No SW: 0BT 300 046 J    HW: 0BH 927 711 G
   Component: DSG DQ500-7F  H11 5301
   Revision: 00H11V01
   Coding: 0014
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_TCMDQ500021 001001
   ROD: EV_TCMDQ500021.rod
   VCID: 3D718FF5AC71A9A2FE-8068
No fault code found.
Address 03: ABS Brakes (J104)       Labels: 7E0-907-37x-MK100ESC.clb
   Part No SW: 7E0 907 379 Q    HW: 7E0 907 379 N
   Component: ESC           H06 0133
   Revision: 00000000    Serial number: 42226000001015
   Coding: 347E4098656584862C7B0279A68221D378F700
   Shop #: WSC 02739 790 50316
   ASAM Dataset: EV_Brake1ESCCONTIVN75XGP2 011001
   ROD: EV_Brake1ESCCONTIVN75XGP2_011.rod
   VCID: 408FF601DB83C44A95-8014
Address 04: Steering Angle (G085)       Labels:* 6R0-959-654.clb
   Part No SW: 6R0 959 654     HW: 6R0 959 654
   Component: LENKW.SENSOR  H07 0070
   Serial number: 06081613471177
   Coding: 01
   ASAM Dataset: EV_LWSKLOVW25X 005001
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EF348F9E1F772BAA7-802A
Address 08: Auto HVAC (J255)       Labels:| 7E5-907-040.clb
   Part No SW: 7E0 907 040 Q    HW: 7E0 907 040 Q
   Component: ClimatronicT5 H03 0613
   Revision: 00001K03
   Coding: 0000000103
   ASAM Dataset: EV_ClimatronicT5 A01003
   ROD: EV_ClimaAutoT5Basis.rod
   VCID: 3169A3C560295DC26A-8064
   Slave 1:
   Subsystem 1 - Part No SW: 7E5 907 049 C    HW: 7E5 907 049 C
   Component: Heckbedienung  H11 0303
   Serial number: BHB-0011808160015143
Address 09: Cent. Elect. (J519)       Labels:. 7E0-937-BCM-V1.clb
   Part No SW: 7E0 937 090 B    HW: 7E0 937 090
   Component: BCM PQ25 Max4 H81 0744
   Revision: B9081001    Serial number: 0982 219161598
   Coding: 7AF8793A0A21201301284F607EEB8EF4C084738960CD79E03204003F0860
   Shop #: WSC 41662 001 104857
   VCID: 2A5BB4A945FF2E1AAB-807E
   Subsystem 1 - Part No: 5K7 955 559 C  Labels: 5K7-955-559.CLB
   Component: RLS 270716 04  42  0106
   Coding: 0228EE
   Subsystem 2 - Part No SW: 7E0 959 801 N    HW: 7E0 959 801 N  Labels: 7E0-959-80X-V2.CLB
   Component: J386__TSG_FT  003 0654
   Serial number: KU0KU011081662242360
   Coding: 0400A1
   Subsystem 3 - Part No SW: 7E0 959 802 N    HW: 7E0 959 802 N  Labels: 7E0-959-80X-V2.CLB
   Component: J387__TSG_BT  003 0654
   Serial number: KU0KU004081662177174
   Coding: 1400A1
   Subsystem 4 - Part No SW: 7E0 959 442 A    HW: 7E0 959 442 A  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H02 0103
   Serial number: 29160001503910046303
   Coding: B4FFFF
1 Fault Found:
03434 - Output for Terminal 30G Interior Lights
            007 - Short to Ground - Intermittent
             Freeze Frame:
                    Fault Status: 00100111
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 240
                    Mileage: 315561 km
                    Time Indication: 0
                    Date: 2017.08.14
                    Time: 14:32:42
Address 10: Park/Steer Assist (J446)       Labels:| 7E0-919-475.clb
   Part No SW: 7E0 919 475 AA    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0212
   Revision: --------    Serial number: 28261616702951
   Coding: 30810C
   ASAM Dataset: EV_VW75XParkAssis8K 001012
   ROD: EV_VW75XParkAssis8K_001_VN75.rod
   VCID: 71E963C5A0A91DC22A-8024
Address 13: Auto Dist. Reg (J428)       Labels:| 7N0-907-572.clb
   Part No SW: 7N0 907 572 C    HW: 7E0 907 572
   Component: ACC Bosch PQx H03 0210
   Serial number: 03081604394656
   Coding: 00005000FE0779
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_ACCBEGVW361 001006
   ROD: EV_ACCBEGVW361_VW32.rod
   VCID: 366390D989477AFA3F-8062
7 Faults Found:
1067 - Brake Temperature
          C10DF 00 [008] -  -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 49
                    Reset counter: 237
                    Mileage: 315119 km
                    Date: 2023.03.15
                    Time: 15:58:04
                    Control Module temperature: 24 °C
                    Voltage terminal 15: 14.7 V
                    Vehicle speed: 0.00 m/s
                    Acceleration: 0.00 m/s˛
1058 - Databus
          U1123 00 [008] - Received Error Message
          [New feature! Extended UDS fault detail is only supported by current gen. interfaces]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 49
                    Reset counter: 237
                    Mileage: 315119 km
                    Date: 2023.03.15
                    Time: 15:58:04
1059 - Databus
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 49
                    Reset counter: 237
                    Mileage: 315119 km
                    Date: 2023.03.15
                    Time: 15:58:04
1037 - Databus
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 37
                    Reset counter: 237
                    Mileage: 315121 km
                    Date: 2023.03.15
                    Time: 16:53:12
                    Control Module temperature: 21 °C
                    Vehicle speed: 28.33 m/s
                    Acceleration: -0.17 m/s˛
1043 - Automatic Distance Control
          B10E7 F0 [008] - Disconnected
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 48
                    Reset counter: 237
                    Mileage: 315119 km
                    Date: 2023.03.15
                    Time: 15:58:04
1119 - Databus
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 49
                    Reset counter: 237
                    Mileage: 315119 km
                    Date: 2023.03.15
                    Time: 15:58:04
1082 - Databus
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 49
                    Reset counter: 237
                    Mileage: 315119 km
                    Date: 2023.03.15
                    Time: 15:58:04
Address 15: Airbags (J234)       Labels:| 5K0-959-655.clb
   Part No SW: 7E0 959 655 H    HW: 7E0 959 655 H
   Component: VW10Airbag01R H08 0018
   Revision: --------    Serial number: 003V4000YW5N
   Coding: 000000000000000000000000000000003152
   Shop #: WSC 02734 790 50316
   ASAM Dataset: EV_AirbaVW10BPAVW12X 001028
   ROD: EV_AirbaVW10BPAVN750_VW12.rod
   VCID: 3B7581EDB265A792C0-806E
   Crash sensor for side airbag: driver side:
   Serial number: 3495ZRB404T3V6TCG12G
   Crash sensor for side airbag: front passenger side:
   Serial number: 3505ZRB400E571NGHHQ1
Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb-SRI1
   Part No SW: 7E0 920 880 S    HW: 7E0 920 880 S
   Component: KOMBI         H04 1105
   Serial number: 00000000000000
   Coding: 140F010400
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05733
   ROD: EV_Kombi_UDS_VDD_RM09_005_VW25.rod
   VCID: 3A7B84E9BD5F9E9ADB-806E
Address 18: Aux. Heat (J364)       Labels:| 7E0-963-27X-18.clb
   Part No SW: 7E0 963 273 A    HW: 7E0 963 273 A
   Component: STH-T5GP2     003 0009
   Coding: 4101
   ASAM Dataset: EV_AuxilParkiHeateWOST5G2 001013
   ROD: EV_AuxilParkiHeateWOST5G2.rod
   VCID: 2B55B1AD4205371250-807E
Address 19: CAN Gateway (J533)       Labels:. 7E0-909-901.clb
   Part No SW: 7E0 909 901     HW: 7E0 937 090
   Component: GW-K-CAN TP20 H81 0744
   Revision: B9081001
   Coding: 042207
   VCID: 68DF0EA19B73DC0A7D-803C
Address 25: Immobilizer (J334)       Labels:| 5K0-920-xxx-25.clb
   Part No SW: 5K0 953 234     HW: 5K0 953 234
   Component: IMMO          H04 1105
   Serial number:
   Coding: 000000
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6ADB74A98D7FEE1A6B-803E
Address 55: Headlight Range (J431)       Labels:. 6R0-907-357.clb
   Part No SW: 6R0 907 357 C    HW: 6R0 907 357 B
   Component: AFS-ECU       005 0050
   Revision: --------    Serial number: --------------
   Coding: 0FCA020001000000
   Shop #: WSC 02757 790 50316
   ASAM Dataset: EV_HeadlRegulVWLWRCC 002006
   ROD: EV_HeadlRegulVWLWRCC.rod
1 Fault Found:
13705987 - Databus
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 47
                    Reset counter: 237
                    Mileage: 315120 km
                    Date: 2023.03.15
                    Time: 16:52:01
Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-STD2.clb
   Part No SW: 5C0 035 680 D    HW: 5C0 035 680 D
   Component: MU-S-N-ER     H31 0356
   Serial number: VWZAZ2S5220960
   Coding: 06570001BE00000011110001000808001F0100D4002001004F
   ASAM Dataset: EV_MUStd4CTSAT 001022
   ROD: EV_MUStd4CTSAT_VW36.rod
   VCID: 224B5C8935CFF65AE3-8076
   Data medium:
   Subsystem 1 - Part No SW: V03 825 254 AG    HW: -----------
   Component: ECE DL1 2023  --- 1910
   Serial number: --------------------
Address 61: Battery Regul. (J840)       Labels:. 1K0-907-534.clb
   Part No SW: 7E0 907 534     HW: 7E0 937 090
   Component: Batt.regelung H81 0744
   Coding: 030B1A73
   Shop #: WSC 02739 790 00000
   Subsystem 1 - Part No SW: 7E0 915 181 K    HW: 7E0 915 181 K
   Component: J367-BDMConti  H03 1050
   Serial number: 75410903001607232060
1 Fault Found:
02256 - Quiescent Current
            001 - Upper Limit Exceeded - Intermittent
             Freeze Frame:
                    Fault Status: 00100001
                    Fault Priority: 7
                    Fault Frequency: 5
                    Reset counter: 236
                    Mileage: 315148 km
                    Time Indication: 0
                    Date: 2017.08.06
                    Time: 03:04:38
End-------------------------(Elapsed Time: 03:26)--------------------------
Friday,24,March,2023,22:14:15:00007
Reactions: mmi
It's what I have mentioned. My Full LED headlamps are OEM, and they are great. I slightly raised the beam, and it shines very well. After my crash, I am surprised that original halogen fog H11 is better visible than H11 LED replacement. So first thing is that I am putting back the "yellow" H11. I still want to work them as designed, even though they do not make that much effect.
I don't think so.
Per wiring diagram
there is a 10-pin connector near horn from where the fog lights are fed - pin 5 (white/blue on BCM side) to the left fog light, pin 6 (yellow) to the right fog light.
