Is it possible with VCDS to alter the speed at which the cornering light function is disabled. Seems the factory setting is 25mph. Would prefer 35mph. Can it be done?
@Dieseldonkey I’m heading to Edinburgh on Friday. Let me know if you want me to bring the laptop with me. (No charge, should only take 5mins if the coding plays ball)
OBD11 developmental data suggests that indeed BCM (module 09) Adaptation Channel 32 is holding the value for cornering light threshold speed. From the factory = 40 km/h.
Channel 33 - angle of steering wheel to switch on. Default = 90.
Channel 34 - angle of steering wheel to switch off. Default = 30.
Channel 37 - intensity Abbiegelicht: Helligkeit
Heres a question, what is your light intensity set to in ch37. My cornering lights are dire & tonight while reversing I thought I'd flick the fogs on & they brighten right up. Just wondered if you knew what yours were set to?
Channel 37 - intensity Abbiegelicht: Helligkeit. EDIT: Default = 80.
When OBD11 is connected to the car it will receive all the coding information from their server.Do you know the long coding bytes bits on module 09 that correspond to these, so i can configure using obd11. I read that cornering light activation for my car is bit one, fourth byte of long code.
