Crafter / MAN TGE Ignition live.
Sam Flanagan
Hi guys,
Not fully a crafter but very close I am struggling to find a fuse diagram for a 2021 MAN TGE.
I am looking for an ignition live for the CTEK 250 if someone had any info on which of the fuses bottom right under the steering wheel would be best to take a feed from.
Thank you for your help!
You could easily ID one by popping a multimeter or circuit tester across the top of each of the blade fuses (in the holes in the fuse tops) when ignition is on then again when off?
