Well, during the first cranking there was no fuel pressure (red) and (thus) injectors were not fired (main injection duration=0).
The second cranking is more interesting - what was done betweeen the first and the second logged cranking? Obviously there was at least one attempt in between the logged two?
- Engine controller thinks it's good to go:
- commands injectors to fire at 3.17 seconds (dark green)
- also rail pressure regulation changes mode
- The pressure build-up is quite slow (from 2.68 to 3.17 seconds when injectors are commanded to fire (injection duration)
- this wouldn't prevent engine to start - just an observation
- IMO indicated Fuel pressure is "too" stable (orange) - it sticks at 32000 kPa even after cranking and then suddenly drops to 0
- Possibly there is still air in the system??
Electrically the ECU seemed to be happy on the seconds logged cranking. However, we cannot conclude if the injectors actually injected fuel.
The first cranking with no pressure is very strange. Was the system bleeded - so was there fuel up to HPFP?
Have you checked the HPPF?
