Just retrofitted a drivers right hand arm rest. Not as easy as I thought. Remove the seat fabric and the foam. Your see the lumber support handle. Undo the lumber support, notch out the hole above the lumber support and move the lumber support handle up to that hole.
Purchase a set of T5 arm rest brackets and a crafter rh arm rest, bolt and cover. I was able to use the set in nut that is tere already and use a riv nut on the circled hole which I drilled out. Used some spacers so the arm rest clears the lumber handle.
Your be left with a hole, the arm rest is at the same level but is slightly longer.
If you have ocd this isnt for you BUT it will save you nearly £2k in trying to find and buy a seat with twin arm rests.
I will add pictures and part numbers later, please try not to reply so I can still edit the post, otherwise please see a post below for pictures and details
