Im not familiar with the revo setup but maybe something centred around the pad/pin spring tensioner thingy (if there is one ?)
Extremely unlikely but :
Stone jammed up the side of the piston ?
Calliper deflecting the disc to one side ?
Disc damaged/corroded/separating halves ?
Think i would get it jacked up and pop the wheel off for a good look around, if you need to the callipers only two bolts to remove then you can see the pads/pistons and also down properly into the disc etc
Hopefully its just a rusty pin or something
@BognorMotors do the revo kit, maybe they have experienced this before ?
Thanks for the suggestions fellas. I'll get the wheel off and have a look over the weekend. They've been on over a year @Dellmassive so should be bedded in by now.
Yes I’ve had this before in one set. Revo themselves had never heard it. However we just loosened and re-torqued the bolts that hold the calliper on and the noise went.
