Tezzzhead
Hi everyone
Does anyone know anything about these CTek split chargers?
I've built my own campervan and read alot about T6s and their smart alternators etc. So I bought a CTek split charger and wired it all in.
It all works fine, the solar charges the new leasure battery and the alternator does to.
I took the van out for its first outing and the leasure battery lasted at about 50 odd % all weekend with music playing lights on etc,
However the starter battery was dead when I went to go home. This was my first issue.
It might of been because I was charging phones off the starter battery not thinking. Also I didn't wire the little red wire to thd ignition as on the diagram it said you dont have to if its a t6.
The second issue is this, how and can I somehow plug the van into a campsite hook up. To hook the van up to a 240 v system when at a campsite.
Normally there is a complete control system that campervans have and you just plug into it. And it switches everything to 240v.
I've wired a little board. So if I install a commando socket and wire it to this little board. Will it just work from the 250v without destroying the 12v system I have wired already. Including the Ctek split charger.
Somehow switch the use of everything to the 240v hookup instead of off the leasure battery?
I'm rather confused to how I can do this alongside my ctek charger?
Or if I ad a AC to DC charger to the leasure battery and keep it charging while at a campsite.
Any ideas?
Any ideas?
