Hi, first post. I hope it's OK to post here, I have a T5 but there seem to be several split charge experts on here and I've not been able to find any help anywhere else, CTEK haven't even replied to me.
So I have a C250SE that has been working fine since I installed it 3 years ago. My solar isn't permanently connected, but this has never been a problem and CTEK told me it was fine to do it that way. This week however I did a 3 hour journey with the fridge running - something I've done plenty of times before. When I arrived at my destination though, my leisure battery (NDS Green Power AGM) was reading 12.4V and the CTEK was in "power saving mode". The starter battery was at 13V. (Note, the T5 doesn't have a smart alternator).
After checking the voltages across the terminals on the CTEK and verifying they agreed with the voltages across the battery terminals I started then engine again. The lights came on to indicate the leisure battery was being charged from the alternator. The voltage across the starter battery from the alternator was 14.5V. Then the lights went out. About 15 seconds later they came on again for about 2 seconds. This on-off then continued until I switched the engine off.
I connected the solar panel and this charged the leisure battery fully, then by evening it was trickle charging the starter battery. So all the connections seem fine.
On my return journey I checked the lights again about 5 minutes in and they indicated charging from the alternator, but when I arrived home once again the leisure battery was at 12.4V and the CTEK was in power saving mode.
There does appear to be a problem somewhere but I'm at a complete loss. I've read a lot of posts about blown fuses and diodes inside the CTEK but my symptoms don't quite match. I'm starting to suspect the alternator but that's only a year old. I'd be very grateful for any help.
