So today I drive to France and on the way back I get the flashing coil and no boost......I just made it to the top of the mountain and checked Carista...23957, 25958 and 16925.....engine idles fine just no power......do a reset and is good for about 2 miles then back to no boost and flashing coil.....ok not far from home will nurse the van back to where I have my tools and Garage.....that may have been a fatal mistake.......power level (not much) gets worse and worse up to the point where van will not climb a hill (thankfully mostly downhill) I decide to pull over and accept defeat in a safe place and the engine will not hold an idle in neutral. so I think turbo is gone.....and possibly oil has been dumped into the DPF as the engine dies with little exhaust fumes coming out the arse end about 4 seconds after starting.....
Oil seems good and temperatures all were good......no other warning lights other than flashing coil.
Van is awaiting recovery this evening........guess first place to look is Turbo and DPF.......hoping it will not be a new engine.
2016 Multivan....... Longlife pro oil every 10000km or 6 months whatever comes first....... Revo Map @ Bognor........Driven hard in Mountains!!!
Any Advice gratefully received........No way I am going to local dealer as they are a shower of W**KERS (Center Prestige Andorra I hope you read this)
Competent mechanic will try to fix at home.....
