DAB issues after amp and RVC
borat
Hi
Has anyone else had issues with DAB after fitting an amp or OEM reversing camera? I had signature audio package from absolut5 fitted and a reversing camera plugged in (OEM). No other changes. Priory to this DAB was fairly reliable. Afterwards it’s terrible. Have since been back and they have checked the connections are ok (both into the head unit and also that nothing was disturbed in the door whilst installing the speakers and sound deadening). They also looked at signal on VCDS and it was 0.7 I believe, though I’m not sure how reliable an indication that is. I’ve added no other new devices and have read the threads about USB chargers etc. The only other thing that happened around the same time was a software update. Any suggestions on what else I could try?
What amp is it. I've found some are worse than others for knocking the DAB out
