Damp ingress by door seal / drivers door
kombisnaps
T6.1 Kombi
Okay so - having a new seal fitted soon for drivers door as worn and a bit naff - vw refusing replace on warranty but hey ho. I did fit a v-dubs one but actually would rather keep it all OEM.
This post however is for a slightly different issue.
When coming to the van in mornings after rain I notice there's often quite a bit of water at the seal, that runs off down the step after door's opened. Doesn't appear to be anything inside the cab though.
There is quite a bit of moisture on door lip underneath the door card though... pics attached. Any ideas?
Took it over to VW today who say door alignment looks fine, and actually even though worn, they personally wouldn't replace the seal - but want to run a water test to see what's what - so spraying it with a hose eh? Next appt though is mid April?!?!?
Any thoughts / anyone who's had similar, it'd be great to know. Ta
Hi,
Afraid I don't have an answer for this but have just been on to Sinclair VW in Cardiff as we're having a similar problem with our T6. Ingress around driver's side slider and fromt passenger door.
Very interested to hear from others if they've had/solved this problem.
Many thanks,
Dave
WhatsApp Image 2024-03-10 at 11.35.02 (1).jpegWhatsApp Image 2024-03-10 at 11.35.02 (2).jpegWhatsApp Image 2024-03-10 at 11.35.02.jpeg
That's outside the main door seal (I don't know if you have the outer "sounds like a Golf" seal)
Either that is just rain getting into the shut lines and not draining well under the door (which doesn't seem a serious issue) or that might be water getting into the door and draining out the bottom, which might be a bit more serious. Obvious area to check is the window seals in the door. A little bit of water is always going to get past and so long as it can get out...
Having someone run the hose over the van and window is likely a good idea if you can do it.
Edited to change the autocorrect typo of "shit lines" instead of "shut lines" - sorry!
We had similar…….firstly the van doesn’t like sitting at angles ( water runs in) I now park on flat area’s…Oem sliding windows leak and after having new door cards replaced and trimmed we decided to seal the widow ( with sealant ) …Also If you’ve had speaker upgrades in the doors they can cause water ingress ( we had @Absolut5 fix it ) ..but keeping the door seals clean and supple helps. ( we use GummiPlege ) and check the roof bolts are sealed ( we’ve used new seals and a drop of sealant on the thread) .
Oem sliding widow’s can be replaced with aftermarkets …at a cost….we are only 2 and have a sunroof so fresh air not a problem so sealing the window was a cheap fix
Ps put a dehumidifier in the van …pulls all the moisture out
Good luck..
Have you had the door speakers checked?
Seen a number of 6.1's with leaky front door speakers.
Mine goes in to VW mid April for a session with a hose / try to find the issue
Mine definitely comes from behind the door Card so I think it’s speaker related
Is all OEM
Update - Went in to VW Loughton and they're replacing the window regulator in the door that's leaking. Had a google and looks like it sits on a plate with a seal that can fail.
Might be worth pushing them to look at that
Get somebody inside the van and somebody to spray a hose on it one area at a time. It should be easy enough to find the cause.
I have the same issue. VW have blamed the supplementary seal I have around the door. I am currently in the throws of testing to see how I can overcome the issue. Interested to know your outcome.
Remove the supplementary seal and go back to VW
Hi all,
Sorry for slow update. Turns out the water ingress in the front footwell was because when the fitters installed the leisure battery, they ran the cables through the same hole in the bulkhead as that used by the tube that drains excess water from the the sunroof opening (brown tube in A column in photo). But they then forgot to re-install the end of the drainage tubing through the bulkhead opening (black rubber funnel on the end of the brown tube, circled in red in the photo). So it was just draining into the cabin! Took it back to installer who was horrified that his team had neglected to re-insert the tube through the bulkhead and sorted on the spot.
He also blew out the drainage holes in the slider windows, took out the windows themselves, cleaned & reinserted them, which solved the problem of water coming in through those windows into the rear area in the van.
Hope this is helpful to some,
D
Ooh this is interesting. We get the exact same leak
Had it all done on warranty and no leaks since
Well looks like the leak is back….
Not sure if related but I clocked the wingmirror last week through a small gap - so not sure if it’s a new one or not
What’s interesting is that there’s a lot of water coming out of drain holes only on opening the doors - so it must be coming in a lot somewhere. Urgggggh - back to VW
