E eetmw Member T6 Pro 14 Feb 2024 #1 Probably the most stupid question… how do I pop a button or usb socket out of the dash or glovebox? Do you twist, pull, use a trim tool? Cheers Toby
The Flying Scotsman Bugger this I’m off fishing VIP Member T6 Legend 14 Feb 2024 #2 Use a trim tool to pop the dash one out
E eetmw Member T6 Pro 15 Feb 2024 #3 The Flying Scotsman said: Use a trim tool to pop the dash one out Click to expand... Thanks, I’m always nervous with plastic bits. I can see from pictures they just have little clips on so I’ll try with a tool.
The Flying Scotsman Bugger this I’m off fishing VIP Member T6 Legend 15 Feb 2024 #4 eetmw said: Thanks, I’m always nervous with plastic bits. I can see from pictures they just have little clips on so I’ll try with a tool. Click to expand... Use the flat right angled one. Get the tip under the USB and prize it off. It’s pretty easy to do
E eetmw Member T6 Pro 15 Feb 2024 #5 Worked great on the dash, can’t get this one out. Do I just need to be a bit more forceful with the tools?
E eetmw Member T6 Pro 15 Feb 2024 #6 The Flying Scotsman said: Use the flat right angled one. Get the tip under the USB and prize it off. It’s pretty easy to do Click to expand... Got it, just needed a screw driver for the added stiffness and leverage. Thank you!
The Flying Scotsman Bugger this I’m off fishing VIP Member T6 Legend 15 Feb 2024 #7 eetmw said: Got it, just needed a screw driver for the added stiffness and leverage. Thank you! Click to expand... You can pretty much disassemble your whole dash with trim tools and a couple torx bits.
