Diesel heater recommendations?
We only fit Eberspacher D2L in our conversions. I like the Webasto but if DIY'ing it can be a bit nicer with the Eber as all the connections are taken care of at the factory, in particular the fuel pump plug so can make your life a little easier.
Great thank you very much for that advice will have a look at that one now. Thanks
Just fitted an AutoTerm Planar type heater with a comfort controller, easy enough to fit. Can't comment on reliability as its only been installed a day :) But it provides hot air to the van and was way cheaper than the perhaps better known products from Eberspacher and Webasto.
AutoTerm Planar type heater with a comfort controller for us as well. Used it all over Ireland in the month of April this year and works a treat. Also blows cold air if needed (here in Spain thats needed!!)
Thank you and hope it does the job for you :)
Reactions: Jet
Great thank you too for the advice :)
