Dodo fleece on the roof
Hello bit of a stupid question. How are people attaching dodo fleece to the roof. I've got hex mat the 5mm thermal liner was then going to fleece it. Don't particularly want to glue it, but can see another way really.
We spray glued ours and it worked out ok. Just make sure that the fleece isn't too thick especially near the fasteners. Replacing the panel can be tricky when working upside down with a tight fit.........oh er Matron!!!
Figured out I had 100mm dodo fleece so I'll use that for all the side panels and get some 50 mm for the roof. I'm using hidden clips as well. Found out that a lot of swearing and a plaster board support works well. I need some extended clips for the middle support bars that go across so they aren't in at the moment
Thanks for the advice
