Sold Dodo Thermo Liner Extreme / 16mm Thick / 1m x 5m Roll / Boxed / £70
bobbybasic
Sold out on deadening.co.uk.
Bought as part of the Campervan Extreme Bundle which came with 2x of these. I used one roll for the sides of my SWB van. I have a pop top so I didn't need this roll.
£70 collection from Brighton (was £90 new in 2021)
  • Product Description​
    * Currently Unavailable
    Dodo Thermo Liner Extreme is a professional 16mm sound and heat insulation material for a quieter warmer, van, camper or motorhome.
    Based on our UK best selling Thermo Van Liner, this 'Extreme' version is designed as the ultimate insulation for a top quality camper conversion. It features a high grade reinforced reflective foil combined with a thick dense 15mm closed cell foam and is ideal for use on the van sides and roof.
    Dodo Thermo Liner Extreme is designed specifically for the UK vehicle market and will improve the comfort of any interior, but is perfect for camper vans, motorhomes, van conversions, Land Rover and vehicle restorations.
    Easily installed this self adhesive product will vastly improve the cabin environment. Temperatures will be controlled, warmer in the winter, cooler in the summer. Less noise makes for a less tiring drive and your radio will sound clearer with less distortion.
    • Extreme 16mm vehicle insulation
    • Thermal liner perfect for camper conversions
    • Dense closed cell design
    • Easy installation - cut, peel & stick.
    • High thermal efficiency
    • Significant noise reduction
    • Warmer in the winter, cooler in the summer.
    • Reduces condensation
    • Will not absorb water like inferior wool or fibre.
    • Acts as a barrier against heat loss
    • Superior Crush resistance
    • Improve van interior comfort
    • Moisture resistant dense closed cell foam
    • Reinforced reflective foil
    • Strong Peel & Stick Self Adhesive
    • High grade construction
    • Fire Retardant
    • Thickness 16mm
    • Total area 5 Square metres (53 Square feet)
    • Roll/Sheet size 1m x 5m
    5sq.m Roll Suitable for Small Van / 4x4
