Does anyone which fuse (if there is one) is for the rear interior lights? I am a VIP member downloaded the guide...but....still in the dark, literally
combatklp
Front interior lights come on when doors are opened or when the switch is pressed, but, nothing in the rear, is there a fuse that might have blown or does the problem lie elsewhere?
Lee
Rear light on the same fuze as interior light? It would be the 7.5 on the left side of the fize box right at the bottom
Thanks, when looking into this, i'm seeing the following two photos for fuse boards - Fuse Board I Have.jpeg
and
Are these fuse boards both in my 2022 T6.1, or is one from a different model? I can only find the first one, and not the second. (which is the one people say the interior light fuse is on.
I'm probably being thick.
The top one is T6.1 fuse board. The bottom one is T6 fuse board.
Fuse SC38 in
However, the fuse supplies all interior lights... front and rear...
Mind if i pick your brains . I’m changing the 2 OEM fitted rear interior lights in the headliner to 2 12v spot lights . Just wondering if i was to trim the connectors off these to attach to the new LED’s would this trip / fault the fuse with the battery connected? Cheers
If you want them to stay on long term that won't work, the standard interior lights feed turns off after 20 minutes or so after the ignition goes off.
Best to start a specific thread for advice and maybe look at Dellmassive's thread:
But yes if you cut the connectors off while power was supplied with metal tools you will have shorted the circuits as one will be 12v and the other one/two grounds (permanent and switched ground via door switches)
Fuse SC38 in
Hi, thanks for the comments above. I have zero interior lights and was wondering, as the fuse pointed out by you on the T6 fuse board looks fine, is there anything else I can check? Any connectors?
My lights have never worked and I am building an ex RAC T6 btw
Does the fuse get +12V.
The only connector after the fuse is in left A-pillar coupling station - white 10-oin connector.
Wiring diagram
Hi, I have checked your photo and unlike this, both of my small interior light looms are still in place. Both look to be in good condition and I have continuity from th solid brown wires to earth. I have belled continuity all the way to the white multiple plugs that are hidden behind the glove box. I have checked for continuity from both sides of that plug to the 7.5 amp fuse. There was no fuse. I have now put a 7.5amp fuse (checked the position was correct by checking with my mate's van by pulling the fuse and his lights went out. I am now in the lovely position of having all the lower dash sections out and trying to remove the actual fuse board. This isn't going well.......
I am convinced there is a break between the white multi plug and the fuse board but cannot get the fuse board out..... Wish me luck
Also, anyone know why when I try and look at wiring diagrams on here it advises me that I need to be a VIP member? I have bought that and my profile shows me as VIP but still no viewing ability.
