Sold Dometic Coolfreeze Portable Fridge/Freezer £250ono
Higgidav
My van has sold so I no longer have need for our portable fridge. I also guess with this hot weather it should be a good time to move along to someone else.
It has worked faultlessly in a wide range of external temperatures.
I have pulled the description below from an eBay advert where a new one is £500.
It holds a surprising volume and yes it will take a bottle of champagne standing up.
It auto switches between 12v and 240v when on hookup.
I’m looking for £250 ono collection from High Peak.
Dometic CFX 28 CoolFreeze Portable Compressor Fridge Freezer 26L​
Dometic CoolFreeze CFX 28 is an efficient fridge use compressor technology. Equipped with a special CFX electronic system, allows to achieve a consistent cooling regardless of the ambient temperature. Freezing is turned off down to -22°C. The USB port is suitable for charging electronic devices.
Thanks to robust design it withstands a field work, at the same time being really lightweight.
Dometic CFX fridge is a great option for anyone who needs a portable refrigerator for outdoor activities such as camping, fishing, off-road.
Dometic CFX 28 Specification​
Brand - DOMETIC
Symbol - Dometic CFX-28
Depth [mm] - 620
Height [mm] - 425
Width [mm] - 342
Weight [kg] - 13
Capacity - 28 Liters
AC voltage - 100-240 V
DC voltage - 12/24 V
Energy consumption (power supply 5/25°C), [kWh/24 h] - 0,175
USB - 5V, 500mA
Inner basket - Yes
Threaded inserts for installation - M6
Drain plug - Yes
Interior lighting - Yes, LED
Purchased in 2020 but only been switched on when camping and when not in use it has been stored in a clean dry environment.
